Dynamic vlan assignment with radius and Aruba Controller
I would like to configure and understand  how to dynamically assign vlan on one ssid by radius attribute? With other vendor this is more easy.
My environment is formed by 7240 controller and access point 135.
Who can help me ? i don' t find a document that describe this solution.
Re: Dynamic vlan assignment with radius and Aruba Controller
What radius server are you using?
Thank you
Victor Fabian
Lead Mobility Architect
MICROSOFT IAS
If you are making policy decisions based on different AD groups then you can use that in combination with a filter ID to assign a VLAN under the Controller Server Group
Thank you
Victor Fabian
Another way you can do this that you assign different role using that same logic I mentioned and then assign the VLAN to the role
Thank you
Victor Fabian
Moderator
Valued Contributor II
Hi Friend,
Adding to the reply by Victor here are steps to configure the RAS policy for dynamic VLAN assignment.
Select  New policy and give a name ( DemoPolicy)
Select Wireless :
Select the user group to map this policy (Manager is a group)
Select  Grant RAS and click on Edit profile
Select Advanced Tab and select Add
Select Attribute name as either Filterid or "Vendor specific". to make your life simple select "Vendor Specific" and click on Add.
Select option, "Enter Vendor-code" the value for Aruba is 14823
Select option "It Confirms" and select "Configure Attributes"
Select the appropriate value and type as shown bellow.
Here for returning VLAN id we should select attribute number as 2 and format  as Integer (Decimal) and finally enter the vlan id as the Attribute value.
The server side configuration is done.
 Now we should configure the server group to assign the return attribute ,
Another way is, map a VLAN to the user role and configure the IAS to return the role name
How to map a VLAN to a Role:
Hope got more clarity,
Please feel free for any further help on this,
Have fun with Aruba :)
Cheers,
Venu Puduchery,
i explain better :
In my environment i have different type of client, with different privilege on network, this type of client reside on  many different campus (different ap group), i have many vlan pool for each campus. The radius should return the value of vlan pool not the vlan. With the configuration shown i understand that is not very flexible...
For example on cisco wlc i only enable a flag to allow aaa override.
The raiuds server sent back to controller the vlan pool, and is not flexible configure a static vlan.
Hi Friend,
Aruba supports this feature,
You can return the VLAN name through RADIUS attribute and you can have a VLAN pool with that name in the controller.
for your ref :
I just configured an attribute to return value test.
I have configured the server group to assign a VLAN pool ( test ).
A VLAN pool with VLANs 11 and 20 :
An user got VLAN assignment through RADIUS .
Hope it is prooved :)
Please feel free for any further help on this.
Cheers,
Venu Puduchery,
