Dear All,
I wouldl like to know the ECCN (Export Control Classification Number) number and HS code for AP-105.
Thanks in advance
Hi There,
ECCN: (not sure)
ECCN 5B002
Wifi Products ECCN 5A992.c
please follow this link for more info:
http://www.bis.doc.gov/encryption/encfactsheet6_17_02.html
http://www.bis.doc.gov/encryption/encfaqs6_17_02.html
HS CODES: (not sure)
851718
847160
852910
OR USE THIS LINK TO FINDOUT:
http://www.dutycalculator.com/new-hs-code-lookup/
ECCN for AP-105: 5A002 (A.1)
HTS for AP-105: 8517.62.0050
HS and HTS codes are related but not the same, but I could not find the HS code.
Awesome ! You've provided the exact information I was looking for.
Would this ECCN and HTS code also apply to other Aruba access points? I have to ship a couple of AP-125s to Hong Kong and I want to make sure I have the correct information.
Thanks!
Yes, there the same for AP-125.
Thank you kindly!
For future reference, is there any available resource online available to handle HTS and ECCN codes for Aruba products? We don't buy our products directly from Aruba, so we don't have an Aruba point of contact directly for this information (other than these forums, of course).
Unfortunately, this information is not available publicly AFAIK.
Aruba employees can access this info on our intranet.
/Onno Harms
How about for antennas, like AP-ANT-1B? What would be an ECCN code for that?
Antennas generally don't require an ECCN but if you need to use one, you can use EAR99.
I need the ECCN number and HS Code for AP-134 & AP-AC-12V18
AP-134 = HTS - 8517620050 / ECCN - 5A992 (mass market)
Power supplies = HTS 8504409580 / ECCN - EAR99
