Regular Contributor II
EVAL-License issue with controller 7005
When I am installing eval licensing in my lab controller its installing and working,
but if I reboot the controller license shows as expired.
Have any one noticed this before ?
I tried several OS but no luck.
Re: EVAL-License issue with controller 7005
How many times have you applied the eval, I believe the max times you can apply one is 3...this is usually shown in the [3] when the license is applied.
If you're happy to provide the output of #show license we might be able to spot an issue.
ACMA, ACMP, ACSA
If my post addresses your query, give kudos:)
I have applied only once,
I believe if we do #write erase all , then we can reuse the license again.
Screenshot is attached.
If you changed the clock, or applied it before you set the clock it might have that behavior.
Nope, I have not changed the clock.
I don't see a screenshot that says it is expired...
But its not showing as enabled also, you can see there is no flag for the license.
Please open a TAC case. I am not sure that we can guess what is going on here.
Unfortunately this is a lab controller and there is no support for this.
Is there any debug command to check ?
I can run as it is a lab device.
