Ethernet Extenders with Aruba AP's
  • 1.  Ethernet Extenders with Aruba AP's
    Posted Aug 12, 2014 08:41 PM
    Has anyone had any experience and/or issues with using Ethernet range extenders to connect Aruba AP's that require 802.3af or 802.3at POE? We have some cable runs over 328 ft, and we're weighing our options. I'm skeptical of using extenders, but additional infrastructure switches may not be feasible due to budget concerns.
    #ALE
  • 2.  RE: Ethernet Extenders with Aruba AP's
    Posted Aug 12, 2014 09:15 PM
    You most likely will not be able to negotiate PoE+ or GigE.
  • 3.  RE: Ethernet Extenders with Aruba AP's
    Posted Aug 12, 2014 11:00 PM
    Anything over the rated length should either use a fiber-extended switch, or a POE-based fiber transceiver. Even if you can up the power to accomodate the length, signal may degrade causing errors, integrity issues, etc.
  • 4.  RE: Ethernet Extenders with Aruba AP's
    Posted Aug 12, 2014 11:15 PM
    Thanks. That's one of the issues I'm worried about. Some extenders claim they work to POE+ levels but I'm concerned about inconsistency causing problems.
  • 5.  RE: Ethernet Extenders with Aruba AP's
    Posted Aug 13, 2014 01:11 AM
    What CAN work doesn't always mean it WILL work. There is some very specific signaling that occurs between the PSE and PD. In some cases they may work fine, in others they won't. Often times these kinds of devices get used and cause JUST enough issues that it creates problems, but are both so innocuous as well as not having any diagnostic output, as to result in customers spending inordinate amounts of time troubleshooting. Better to just see what happens at 328 feet than to insert a non-standard device into the mix (IMHO).
    But a more supported solution would be a PoE+ fiber transceiver. Check our Ecosystem Partner page for vendors
    http://www.arubanetworks.com/partners/ecosystem/
  • 6.  RE: Ethernet Extenders with Aruba AP's
    Posted Aug 14, 2014 07:38 PM
  • 7.  RE: Ethernet Extenders with Aruba AP's
    Posted Dec 21, 2017 05:49 PM
