Contributor I
Failover and centralised licensing
This has probably been covered elsewhere, but could I ask how I would quote a solution where someone needs a air of 7210's, 1 in failover mode, is it just 2 x part number 7210?  Also, if they are using Centralized Licensing, and they need 512 AP's covered, do they just buy 512 AP licences and use a licence server to distribute them out?
Jamie.
Re: Failover and centralised licensing
Correct.  2 7210s 512AP license if you need 512 APs.  If you order PEFNG, you order 512 PEFNG, as well.
