Occasional Contributor I
Firewall and dpi
Since one month, we have an issue with our W7210 firewall.
We have an open SSID with an external captive portal (10.7.0.255).
occasionally the https trafic from clients to captive portal is allowed by aruba firewall but sometimes not:
(STARSKY) #show datapath session table 10.7.37.221
       Q - Real-Time Quality analysis
       E - Media Deep Inspect, G - media signal
       A - Application Firewall Inspect
Source IP       Destination IP  Prot SPort DPort Cntr  Prio ToS Age Destination TAge Packets    Bytes      Flags
10.7.37.221     10.7.0.255      6    50629 443    0/0  0    0   0   tunnel 2332 1    0          0          FDYCA
How can I investigate this issue ?
Re: Firewall and dpi
What is the ip address 10.7.37.221?
It's my test client, can you explain me the A flag ?
Does it seem the dpi have blocked it ?
A just means that it is looking at it.  What role do you have the client in and what rules do you have?
On the commandline type "show rights <role>"
my client have "eduspot" role, role detail attached.
Are you trying to block eduspot?
deny-inter-user
Priority  Source      Destination           Service  Application  Action  TimeRange  Log  Expired  Queue  TOS  8021P  Blacklist  Mirror  DisScan  ClassifyMedia  IPv4/6  Contract
1         user        10.7.0.255            any                   permit                           Low                                                           4
2         10.7.0.255  any                   any                   permit                           Low                                                           4
3         user        10.7.0.0 255.255.0.0  any                   deny                             Low                                                           4
deny-broadcast-eduspot
1         any     10.7.255.255  any                   deny                             Low                                                           4
My network mask is 255.255.0.0 (/16)
What I want to do:
1 : Allow user to reach the captive portal IP which is 10.7.0.255
2 : Allow captive portal to reach clients
3: Block trafic between users
4: Block broadcast
user        10.7.0.255            any
1,2 That is the only line you will need to allow users to reach the captive portal.  The firewall is stateful, so it will allow responses to user queries.
3. In the Virtual AP profile, you can enable "Deny Inter-User Traffic"
4.  In the Virtual AP profile, you can enable "Drop Broadcast and Unknown Multicast"
Now wihthout modify anything, the trafic is going on !
10.7.37.221     10.7.0.255      6    51465 443    0/0  0    0   0   tunnel 2332 3    56         4184       FC
10.7.0.255      10.7.37.221     6    443   51465  0/0  0    0   0   tunnel 2332 3    75         86820      F
Any idea ?
Are you blocking any traffic using the apprf dashboard?
