GE Dash wireless devices broadcast traffic not functioning
  • 1.  GE Dash wireless devices broadcast traffic not functioning
    Posted Nov 18, 2013 04:30 PM
    At a Hospital we have some GE Dash 4000 units that use our wireless network in order to communicate with their seperate network.  These devices are all 802.11b and they work off broadcast.  The way they work is that each unit sends a broadcast every 45 seconds.  Anyone that sees that traffic can make a unicast communication with that device to monitor the device's output, in this case patien vital signs.  Now, this works fine when the devices are connected to the the GE wired network, but not when the devices are connected to our wireless network.
    The devices on wireless can see all the other devices, so they are receiving broadcast traffic, but non of the other devices can see the wireless units.
    When checking the datapath session, I can see broadcast traffic from/to the host.
    126.7.x.x 126.255.255.255 17 3200 7000 0/0 0 0 1 tunnel 1630 11 FC 0/0 0 0 0 local
    126.255.255.255 126.7.x.x 17 7000 3200 0/0 0 0 1 tunnel 1630 12 FY 0/0 0 0 0 local
    The clients state that they noticed the issue happen about 3 months ago, which is about the time when we replaced all the AP70s in that site with AP105s.  Anyone have any clue what could be causing the broadcast traffic from the device not being seen by the other hosts?  The broadcast traffic to the host is being seen, but not the other way around.  We don't have broadcast disabled, hence it's working one way.
    #3200
  • 2.  RE: GE Dash wireless devices broadcast traffic not functioning
    Posted Nov 18, 2013 04:39 PM
    One similar issue that we found while searching online is a Cisco issue after upgrading a controller. They mention that Enabling 802.11 Padding fixed the issue.  Does Aruba have a similar setting for this Cisco option?
    https://supportforums.cisco.com/thread/2047973
  • 3.  RE: GE Dash wireless devices broadcast traffic not functioning
    Posted Nov 19, 2013 08:04 AM
    Have you tried doing a wireless packet capture ?
    Can you try connecting directly from the controller and see if it works to rule out the VLAN / Controller / AP ?
    And I know you mentioned that the drop broadcast is not enabled but can you check under the VAP ?
    (controller) #show  wlan virtual-ap NORTH1-SECURE-VAP-B
    Virtual AP profile "NORTH1-SECURE-VAP-B"
    Parameter                                       Value
    AAA Profile                                     AAA-NORTH-SECURE-DOT1X-PROFILE-B
    802.11K Profile                                 default
    SSID Profile                                    NORTH1-SECURE-SSID-PROFILE-B
    Virtual AP enable                               Enabled
    VLAN                                            LOCAL1-VLANS-POOL-B
    Forward mode                                    tunnel
    Allowed band                                    all
    Band Steering                                   Enabled
    Steering Mode                                   prefer-5ghz
    Dynamic Multicast Optimization (DMO)            Disabled
    Dynamic Multicast Optimization (DMO) Threshold  20
    Drop Broadcast and Multicast                    DISABLE
    Convert Broadcast ARP requests to unicast       Enabled
    Authentication Failure Blacklist Time           3600 sec
    Deny inter user traffic                         Disabled
    Deny time range                                 N/A
    DoS Prevention                                  Disabled
    HA Discovery on-association                     Disabled
    Mobile IP                                       Disabled
    Preserve Client VLAN                            Disabled
    Remote-AP Operation                             standard
    Station Blacklisting                            Enabled
    Strict Compliance                               Disabled
    VLAN Mobility                                   Disabled
    FDB Update on Assoc                             Disabled
    WMM Traffic Management Profile                  N/A
  • 4.  RE: GE Dash wireless devices broadcast traffic not functioning
    Posted Nov 19, 2013 09:39 PM
    Yep, had checked and double checked everything.  Spent half the day today troubleshooting the issue.  We finally found that having an IP address on the SVI for that vlan on the controller fixed the issue.
    Can anyone explain why that is?  It's only a L2 connection.  Is best practice to have an IP address on every SVI even though they are just L2?
