GRE Striping and AP Failover
  • 1.  GRE Striping and AP Failover
    Posted Dec 18, 2014 04:13 AM
    I know there are lots of posts on this but I was wondering if somebody could clear up how GRE striping should be configured in an AP failover scenario.
    The following configuration is being used:
    Master controller - 10.10.10.10
    Local controller - 10.10.10.11
    Both controllers have the GRE LMS LACP mapping set as below:
    ap-lacp-striping-ip
    aplacp-enable
    striping-ip 10.10.10.13 lms 10.10.10.10
    APs are in an AP group which has an AP system-profile configured as below:
    ap system-profile "Master_Hosted"
    lms-ip 10.10.10.10
    bkup-lms-ip 10.10.10.11
    lms-preemption
    and also HA fast failover is configured as below:
    ha group-profile "HA_Group1"
    preemption
    controller 10.10.10.10 role dual
    controller 10.10.10.11 role dual
    Both controllers show the AP as up with striping enabled (the s flag is there on 'show ap database long' from both controllers).
    Connections work fine on the master controller but when I failover the AP to the local controller, the 'a' radio works fine but the 'b/g' radio doesn't allow connections.
    I have been through numerous configurations with GRE striping to LMS IP but can't get this to work.
  • 2.  RE: GRE Striping and AP Failover
    Posted Dec 18, 2014 07:03 AM
    Does each controller have a unique striping IP (x+1)?
  • 3.  RE: GRE Striping and AP Failover
    Posted Dec 18, 2014 07:15 AM
    Hi Tim,
    I've played with multiple configurations but originally each controller had its own striping IP as below:
    striping-ip 10.10.10.14 lms 10.10.10.11
