@cclemmer wrote:
@benm87 wrote:
Hi all,
I have a simple network consisting of three 215 iap's and one 205 iap.
I have two networks set up on the virtual controller; one as a normal unrestricted network, and another setup as a guest network with the client ip managed by the virtual controller.
The download speed on the unrestricted network is reaching excess of 180mb/s whereas the speed of the guest network reaches a max of 8mb.
All access points are plugged into an unmanaged POE switch which is plugged directly into a standard ISP issued router.
Any ideas on where/why the speed could be limited on the guest SSID?
Thanks in advance
Which AP is the currently elected master? Which AP are you associated to when testing, both the "unrestricted" network and the "guest" network? What else is going on in your environment while you're testing download speed?
Thanks for the reply,
Currently one of the IAP215's is elected as the master. Would it make a difference if the 205 was the elected master?
I've tried being associated with each of the AP's when testing, and I've even disconnected the 205 in case there was an issue there, but I had the same result in each scenario.
As this is a new install, It's only my laptop, phone or ipad connected to the network during testing in which I have the same results on each device.
I've even looked at the router that the access points/switch are connected to but I can't see anything suspect at this point.
Thanks again for your help
