Hello!
OK.
But LMS would be used at the initial connection.
The backup tunnel would be established to the second controller, like its set in the HA Group Configuration.
So if i leave backup LMS blank at the AP Group configuration and set the LMS IP to the VRRP VIP, it would not work?
I understand that the AP only connects to the backup LMS if the LMS is down.
So my conclusion is that, if the VRRP Master is down, a rebooting AP would connect to the VRRP Backup wich is now master.
The only thing is, the backup tunnel can not be established along the HA Group configuration because one controller is down.
