Hard disk requirement for ArubaOS8.2
  • 1.  Hard disk requirement for ArubaOS8.2
    Posted Apr 27, 2018 01:42 AM
    Is there any requirement for harddisk used for hosting VMM/VMC? For example, harddisk speed etc.
    Thanks.
  • 2.  RE: Hard disk requirement for ArubaOS8.2
    Posted Apr 27, 2018 02:27 AM
    It's covered in the AOS 8.2 Virtual Appliane Installation Guide that you can download from support.arubanetworks.com.
  • 3.  RE: Hard disk requirement for ArubaOS8.2
    Posted Apr 27, 2018 02:50 AM
    What I am checking is information such as harddisk RPM speed. I could find this information on the ClearPass C1000/C2000/C3000 datasheet but not on the VMM. Thanks.
  • 4.  RE: Hard disk requirement for ArubaOS8.2
    Posted Apr 27, 2018 10:53 AM
    @MiniMewrote:
    The VMM is not disk IO bound like ClearPass or Airwave. The bigger concern is that memory and CPU allocation should not exceed overall host capacity, and that CPU, memory, and network throughput should not exceed 80% of the host capacity.
  • 5.  RE: Hard disk requirement for ArubaOS8.2
    Posted Apr 27, 2018 07:13 AM
    In the summer when the students are gone..
