Having issue managing AP 360 via VM using IAP305, The IAP305 can not pick up the AP360. A
Having issue managing AP 360 via VM using IAP305, The IAP305 can not pick up the AP360. Thank you in advance.
Re: Having issue managing AP 360 via VM using IAP305, The IAP305 can not pick up the AP360. A
You need to be running a minimum of
Unified ArubaOS and InstantOS 6.5.2.0 in the cluster.
http://www.arubanetworks.com/assets/ds/DS_AP360Series.pdf
