Help with 3200 and SSID
I'm a newbie at this so please excuse the dumb questions:
I have a 3200 controller with 7 AP's
All AP's are in a group and i can see them as "UP"
I created a new wireless lan with the wizard, goes to finish but i cannot see the newly created SSID / WLAN on my network.
Since doing this i have two amber lights on my AP's where as before they were all green.
anything obvious i'm missing ?
thanks
Re: Help with 3200 and SSID
What else did you change?  Go on the commandline and type "show audit-trail" to determine what caused your problem.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Make sure you have added the VLAN to VAP
do a show profile-errors too
Thank you
Victor Fabian
Lead Mobility Architect @WEI
