Hi guy! I need help
I´m familiarizate to replace the default certificate securelogin.arubanetworks.com in Aruba instant with a wildcard certificate but not in Aruba controllers.
Two questions?
- In controllers family is a wildcard certificated allowed?
- Once you replace the certificate, Is the URL "captiveportal-login.mydomain.xx" instead of securelogin as is in instant family? Needed to know to replece the redirection in the CPPM.
Frequent Contributor II
Re: Hi guy! I need help
- Yes wildcard certs are allowed in controllers as well.
- Yes, after cert addition, you need to update ClearPass guest page to "captiveportal-login.mydomain.xx".
JayBee
ACDX | ACCX| CCIE (RnS/SP,DC) | ACCP | ACMP | ACSA | ACMA | JNCIS | JNCIA
If the provided solution resolves your issue, please mark it as accepted solution to help others.
