How can I change AP-61 air-monitor to ap-mode?
  • 1.  How can I change AP-61 air-monitor to ap-mode?
    Posted Nov 22, 2011 01:33 PM
    I don't need Air Monitor in my environment and select ap-mode in Radio Profile but 3 of my AP-61 become air monitor, while AP-105 work in proper ap-mode. how i can change AP-61 air-monitor to ap-mode.
    controller is A-200 with OS v. 5.0.3.3.
    Thanks.
  • 2.  RE: How can I change AP-61 air-monitor to ap-mode?
    Posted Nov 23, 2011 05:47 AM
    You should probably post this in the appropriate forum rather than on a blog post. However there are separate radio profiles for 802.11g and 802.11a radios so you might have the mode set to ap-mode on the 802.11a profile but not on the 802.11g profile.
    James
  • 3.  RE: How can I change AP-61 air-monitor to ap-mode?
    Posted Nov 30, 2011 06:49 AM
    @mhnasir wrote:
    Thanks.
    Do you have mode aware arm turned on? If that is the case, the only way you could force those three AP-61 back into ap mode, without turning off mode aware, is to create ap specific profiles for those three AP-61. In the ap specific profile, disable mode aware arm.
