How to Disable Block Acknowledge feature in 802.11n enabled Aruba AP ?
  • 1.  How to Disable Block Acknowledge feature in 802.11n enabled Aruba AP ?
    Posted Apr 05, 2016 08:34 AM
    I would like to disable Block Ack in 11n enabled Aruba AP for my internal testing.Please tell me method for that.
    I know switiching to 11a resolves the question but i would like to keep 11n intact.
  • 2.  RE: How to Disable Block Acknowledge feature in 802.11n enabled Aruba AP ?
    Posted Apr 05, 2016 08:43 AM
    I think that is not something that is an option when you enable 802.11n.  That is part of the standard..
  • 3.  RE: How to Disable Block Acknowledge feature in 802.11n enabled Aruba AP ?
    Posted Apr 05, 2016 08:51 AM
    I Agree that BA is part of standard, But my stations are having problem with Block ack so i have permanently disabled it in device. I want to remove ADDBA from AP so want to disable Block Ack in AP.
  • 4.  RE: How to Disable Block Acknowledge feature in 802.11n enabled Aruba AP ?
    Posted Apr 05, 2016 08:52 AM
    What device is this?
  • 5.  RE: How to Disable Block Acknowledge feature in 802.11n enabled Aruba AP ?
    Posted Apr 06, 2016 09:25 AM
    You can change MPDU aggregation, block ack, from the command line:
    (ArubaController) #configure terminal wlan ht-ssid-profile {profile_name}
    (ArubaController)(High-throughput SSID profile "{profile_name}") #no mpdu-agg
    From the GUI the change can be made from Configuration > AP Group > Wireless Lan > VAP Profile > SSID > High-throughput SSID (advanced) > MPDU Aggregation unchecked.
    I agree with Joseph that this is a standard and you are going to be making this change at the detriment of other device types connecting to this particular SSID.  I would test this in a lab before deploying.  Make sure that this change is applied only to the SSID it is needed.  Don’t assign this to the any of the default profiles.
  • 6.  RE: How to Disable Block Acknowledge feature in 802.11n enabled Aruba AP ?
    Are you talking about the WIDS signature for Block Ack attacks? Ah sorry, I only read the body, not the header. I've never seen anyone need to disable. What is the reasoning for it?
