How to check network port speed for every access point
Before i started working for my current employer, they had contracted installation of AP-225's district wide, and I've seen several access points that weren't running at gigabit that I still have to troubleshoot - my guess is the cabling termination is faulty.  (that's 2 access points in a building with 146).  I've seen this issue in a few other locations and
It would be exceedingly handy if there were a method that would allow for a wild card that would display the port speed for all of the access points connected to a controller.
Searching has netted me a database extration script that I can't run because of the version of airwave deployed.
Both CLI commands I've seen require unique AP identification - ap-name, or otherwise ("show ap debug" and "show ap port status "  either of these commands would require significant work to check 1200+ access points.
Is there another method for displaying this data?
Re: How to check network port speed for every access point
why don't you use a combination of
'show ap database long'
extract the AP names out and put them in an excel file in column A1
Column A2 would look like this
="show ap port status ap-name "&A1
Drag down to get the command to output every ap name and then copy/paste into the controller.
Save your SSH session to a text file and then go through the output?
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Good idea....
Thanks!
For what it's worth, I imported the "show ap database" into excel using space delimiters and then used concatenate to create the script
=CONCATENATE("show ap port status ap-name ",A1, " | include Mb")
Which helped me find ~ 25 access points (out of 1250) with connectivity issues.
Thanks again.
