Hi all,
I have Aruba AP 105 and configured to capture raw packets. When i sniff packets using Wireshark or OmniPeak, the captured packtes doesn't contain radiotap header which is required to get the RSSI value. Can anybody help?
If you capture with an AirPcap adapter you will see the radiotap info.
When using packet capturing on the AP-105 and sending to OmniPeek, you should see noise floor and signal level in the packet info section of the decode:
