How to enable Bandwidth per client ?
Each user that authenticates ends up in a ROLE. Roles are defined under Configuration> Security> Access Control.
Edit the role that the user is in and Add a Bandwidth Contract for Up and/or Down depending on what you want to limit.
can you please provide the screenshots for configuring the same???
Thank You
I do not have a screenshot. Below is a copy of the instructions from the user guide.
