Frequent Contributor II
How to move AP134 from instant to controller
I have an AP134 that used to be instant, and now I want it to be contoller-based.
I connected a console, got to apboot> and did a factory reset. Every time it comes up, it comes up with Instant and the controller does not see it to provision it.
Help!
Re: How to move AP134 from instant to controller
Connect to the instant SSID, login to the UI, go to the maintenance tab and convert it to a campus AP.
Tim Cappalli | Aruba Security
thanks. Figured that out moments after posting. I looked in the console page for the DHCP assigned IP, web connected to that, admin/admin and did the convert.
Many thanks
