How to set controller administrator role if using external server for controller admin login auth
  • 1.  How to set controller administrator role if using external server for controller admin login auth
    Posted May 20, 2016 02:22 AM
    Hi , we want to use external tacacs server to authenticate controller admin login, but need to set different role ( root and read only) for different user. How to set the parameter on the tacacs server so that the aruba controller can recognize the  return value of role setting from tacacs?  Another question, if we use external server for authentication, then when the external down, we are not able to login onto the controller?
    Thanks in advance.
  • 2.  RE: How to set controller administrator role if using external server for controller admin login auth
  • 3.  RE: How to set controller administrator role if using external server for controller admin login auth
    Posted May 20, 2016 09:15 AM
    thanks a lot for your reply
  • 4.  RE: How to set controller administrator role if using external server for controller admin login auth
    Posted May 20, 2016 09:28 AM
    Sorry, one more question, do we need to add radius dictionary file for cisco ACS on ACS ? Thanks
  • 5.  RE: How to set controller administrator role if using external server for controller admin login auth
    Posted May 24, 2016 09:06 AM
    if you use TACACS+ you don't need any libraries.
