How to turn off LEDs of APs?
This thread has been viewed 19 times
  • 1.  How to turn off LEDs of APs?
    Posted Mar 22, 2012 07:18 AM
    Someone told me that LED-signs of APs could be turned off (to keep users calm not having a blinking device above their heads). How can i do this?
    We have 105 and 135 APs and a 3200 Controller.
    #3200
  • 2.  RE: How to turn off LEDs of APs?
    Posted Mar 22, 2012 07:21 AM
    (host) #configure terminal ap system-profile default led-mode off
    (host) #configure terminal ap system-profile default led-mode normal
  • 3.  RE: How to turn off LEDs of APs?
    Posted Mar 22, 2012 09:45 AM
    That worked!
    I also found the representation in the Web-GUI.
  • 4.  RE: How to turn off LEDs of APs?
    Posted Mar 04, 2013 12:20 AM
    Can we really turn off LIghts on AP 105 with OmniVista 3600 controller. Also can it be VIA gui ?? or have to console in AP and then do it ?
  • 5.  RE: How to turn off LEDs of APs?
    Posted Mar 04, 2013 12:30 AM
    You can do it via the GUI in the AP system profile.  No need to console.
  • 6.  RE: How to turn off LEDs of APs?
    Posted Mar 04, 2013 12:37 AM
    Thanks a lot. :)
  • 7.  RE: How to turn off LEDs of APs?
    Posted Oct 21, 2013 01:18 PM
    Can this be done on a per AP basis though?   i have an AP installed in a darkroom that is messing up some film processing. I want to diable the LED's on that particular AP but not the rest of the other AP's using the same profile.
  • 8.  RE: How to turn off LEDs of APs?
    Posted Oct 21, 2013 01:20 PM
    Yes, you can do it on a per-AP basis under AP Specific.
  • 9.  RE: How to turn off LEDs of APs?
    Posted Oct 21, 2013 02:16 PM
    Sweet.  Thanks!
  • 10.  RE: How to turn off LEDs of APs?
    Posted Aug 17, 2017 10:17 AM
    Tim, is there a way to do this through the GUI for IAPs?
  • 11.  RE: How to turn off LEDs of APs?
    Posted Aug 17, 2017 10:55 AM
    In the system --> General tab, click on 'show advanced options'.
  • 12.  RE: How to turn off LEDs of APs?
    Posted Aug 18, 2017 08:50 AM
    Thanks, Michael - appreciate the help; however, what I'm wondering is whether this can be done on only specific APs rather than the entire cluster. Is that possible?
