I have A and B building distance between 4 to 5 km which outdoor access point will support ..LOS
Clear ... MST 200 will support ?
MST200 will likely work, but thoughput will be low (15-20Mbps max), the 274 with ANT-2x2-5314 will likely be much faster (depending on channel bandwidth you can support, but should be at least twice the MST200 or more if you can use wider channels).
