I need a AP without a radio.
  • 1.  I need a AP without a radio.
    Posted Jul 05, 2016 04:36 AM
    We are using the Aruba controller with AP's on the company locations, perfect.
    Also in some cases I used the AP second Ethernet port for a bridged vlan's over locations, need it.
    Is there a AP without any radio and with some Ethernet ports?
    Thanks!
  • 2.  RE: I need a AP without a radio.
    Posted Jul 05, 2016 05:42 AM
    There is no AP without a radio. You can disable the radio on any AP, however. There are remote access points on the page here (model numbers begin with RAP): http://www.arubanetworks.com/products/networking/access-points/ that have second Ethernet ports that would fit your need.
  • 3.  RE: I need a AP without a radio.
    Posted Jul 05, 2016 06:55 AM
    Try the RAP-155 or RAP-109 or even a AP-205h
