I need some advice!!
I have two 7030 controllers and two 7210. I would like to see if I can have the 7030 to be Master-Backup master while having the 7210 to be local-local and get theri configs from the Masters(7030)?
the real question is: can I have the masters to be a model and the local to be a totaly differant model?
Thanks.
Re: I need some advice!!
Absolutely.
