- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
12-13-2015 04:36 AM
Hi all,
As we dont have many rogue AP's around, i have disabled ARM, and am using manual settings for my radios.
However, i have noticed a difference in what i have set, and what (i believe) is being transmitted...
This is what is showing under Access Point...
And this is what is set in the AP config...
Throughput seems ok on all clients etc, so im not really sure how or what the settings sgould be to get maximum performace.
Apologies for all of the questions..Just learning!!
Thanks!
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: IAP 215 Transmit Power setting.
12-13-2015 04:42 AM
Depending on the access point, there are regulatory power constraints. On the commandline, type "show ap allowed-max-eirp"
Colin Joseph
Aruba Customer Engineering
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-13-2015 05:55 AM
Well, ive tried the CLI but for some reason it wont let me access it as its says my password is invalid, even though i havent changed anything like that on the AP yet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-13-2015 05:58 AM
Colin Joseph
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-13-2015 06:10 AM
Ah ok, so max is power is dependant on actual channel number eg 36 or 100 etc on 5ghz?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-13-2015 07:15 AM - edited 12-13-2015 07:25 AM
...and AP model number and if you are bonding channels or not. Here is the output from a 225 (scroll to see everything...there are alot of columns):
(Aruba7005-US) #show ap allowed-max-EIRP ap-name Main-225 Max EIRP setting for AP-225 --------------------------- Channel 1 2 3 4 5 6 7 8 9 10 11 12 13 14 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 144 149 153 157 161 165 ------- - - - - - - - - - -- -- -- -- -- -- -- -- -- -- -- -- -- --- --- --- --- --- --- --- --- --- --- --- --- --- --- --- --- --- b 29 29 29 29 29 29 29 29 29 29 29 * * * * * * * * * * * * * * * * * * * * * * * * * * * * g/a 32 32 32 32 32 32 32 32 32 32 32 * * * 21 21 21 21 28 28 28 28 28 28 28 28 28 * * * 27 27 27 27 33 33 33 33 33 HT 20 32 32 32 32 32 32 32 32 32 32 32 * * * 21 21 21 21 27 28 28 28 28 28 28 28 28 * * * 27 27 27 27 33 33 33 33 33 HT 40 32 32 32 32 32 32 32 32 32 32 32 * * * 20 20 20 20 24 24 24 24 24 24 24 24 * * * * 24 24 24 23 32 32 32 32 32 VHT 80 * * * * * * * * * * * * * * 21 21 21 21 21 21 21 21 21 21 21 21 * * * * 21 21 21 20 33 33 33 33 33
The technical answer (but not all encompassing answer) for all of this is in the thread here; http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/AP-275-emitting-power/m-p/192051/highlight/true#M38612
Colin Joseph
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-13-2015 08:33 AM - edited 12-13-2015 08:41 AM
Ok, interesting, however, that means my IAP215 should be outputting more than it is showing, especially if what it shows is the actual EIRP?
According to the spec sheet on the Aruba website, it states a maximum of 23dbi plus antenna gain for EIRP for both the 2.4 & 5 radios of 5dbi each
With that, i thought i would be getting closer if not the maximum when set manually as our UK maximum is 30.
Also.... my AP is currently ARM on channel 116E.
What is the 'E'?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-13-2015 08:46 AM
The chart above is for the AP 225 (I don't have an AP 215). If you can run the command on the commandline of your IAP you will get a chart for that AP's model
The E means 80 mhz channel. Quite frankly, if you cannot get the commandline, you will not have the information needed to explain the output and you will probably have to trust us...
Colin Joseph
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-13-2015 09:01 AM
No. i totally trust what you are saying!
Its more of me understanding how things work etc.
I am a complete a complete novice with Aruba (and detailed netwroking)!
As for the CLI, for some reason in terminal on OSX, i can ssh the IP address, but it says permission denied when i put in the defaul password.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-13-2015 09:09 AM
Are you using the admin username?
Colin Joseph
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
