Occasional Contributor I
IAP-275 with PoE injector 15.4W 802.3af
Hey there everybody,
We're installing a couple of IAP-275 but we only have sone 802.3af power injectors. What do I lose when using this standard instead of the recommended 802.3at?
Re: IAP-275 with PoE injector 15.4W 802.11af
The 270 series require at power.
Tim Cappalli | Aruba Security
So it wont even function 1x3 instead of 3x3? or maybe just lose the USB function?
No, the 270 series require at power. Limited functionality is available on indoor APs.
