Looking for outdoor coverage on the corner of a building. For simplicity sake, let’s just say the corner of the metal building is 90 degrees, and I want to cover the east and south sides. Would need about 10 feet of 400 series coax running inside to the AP for each antenna, and the necessary connectors/whips/lightening protection.
Can I use two AP-ANT-6 antennas, one facing each direction on the corner of the building?
And if so...can I connect both of these antennas to a single IAP-92? Or do I need two IAP-92 access points in the corner, connecting one antenna to each AP, leaving one antenna connector unconnected?
I’m pretty new to this stuff, so please be nice!
-Gerry
