Goal is to have access to a locally statically assigned IP address on my 3rd party firewall's management interface that is connected to ENET1 on my IAP from my wireless clients.
My working set up on the IAP is...
- Port 0 is my uplink to my ISP modem (Trunked port).
- Port 1 is my Access port for plugging in a wired device, ie a laptop.
- I also have two SSID's that broadcast.
- All of this works, the IAP hands out IP addresses via DHCP correctly, I can access the internet from both wired and wireless, etc.
What I can't get to work...
- ENET 0 is my uplink to my ISP modem (Trunked port)
- My wireless connectivity still works.
- ENET 1 (Access port) is connected to the management interface of my firewall.
I have to manually configure this IP address locally on the firewall.
So my assumptions are that by default, 172.31.98.0/23, is managed by the IAP.
I created a smaller DHCP scope on the IAP to be 172.31.98.0/26 under DHCP Servers (I only configured the top part - not Distributed, Centralized, Local Scopes because when I manually set the VLAN ID, everything gets disconnected so I am assuming the IAP is just managing this automatically)
Then statically assigned my firewall's management interface to 172.31.98.254, assuming that this range is still 'in scope' for the IAP.
I see the IP and MAC address of my firewall's management interface in the wired section of Wired Users of the IAP.
I can't ping nor access my firewall's management interface.
How can I have both the IAP hand out addresses via DHCP to my wireless clients, and then allow internet and wireless client access to a statically assigned address of my firewall using ENET 1?
Thanks in advance.
