last person joined: 5 hours ago
  • 1.  IAP to CAP
    Posted Jul 27, 2018 01:33 AM
       I have 70 IAP all new in the box, we want to deploy them at one of our branch offices as a controller base. is there a way to convert them to from IAP to CAP without creating IAP cluster first and then transfer them?
  • 2.  RE: IAP to CAP
    Posted Jul 27, 2018 04:05 AM
    Not that I am aware of, I think the only way is to convert them in batches. Unless this has changed in the new unified AP OS
    However, its' pretty easy to convert them all at once:
    • You'll need to whitelist them on your controller first.
    • Connect all the IAPs to your network but only boot one at this stage. This will become the master IAP
    • Connect to the Instant SSID
    • Using a browser, visit http://instant.arubanetworks.com
    • Password admin admin
    • As you have multiple IAPs to be converted, they should be booted now (after the first IAP has started up completely) - the extra IAPs will swarm to join the Instants AP master; when conversion takes place, all the IAPs in the swarm will be converted together. The number of APs which have joined the swam will update in the web page displayed after logging in to the first one.
    • Select the Maintenance link in the top right corner of the page
    • Select the Convert tab.
    • In the drop-down list select Campus APs managed by a Mobility Controller in the IP address box, enter the IP or hostname of your controller
    • Click convert now
    It can take up to 15 minutes for the conversion to take place.
    Hope that helps
    Alexander.
  • 3.  RE: IAP to CAP
    Posted Jul 27, 2018 06:18 AM
    Hi
    Which model of AP?
    You can do this quicker by concole.
    1. Power on the AP
    2. stop the boot process
    3. setenv master <ip address MC>
    4. setenv serverip <ip address MC>
    5. saveenv
    6. boot ap
    Hope this helps
  • 4.  RE: IAP to CAP
    Posted Jul 27, 2018 07:05 AM
    @mrtwentytwo wrote:
    Hi
    Which model of AP?
    1. Power on the AP
    5. saveenv
    6. boot ap
    Hope this helps
    I may be wrong but to be able to do this from a boot I think this has to be an AP that ships with  ArubaOS 6.5.2.0 or above i.e. from the Unified AP platform.
    Also if the IP of the master / switch is saved directly into the AP, am I correct in thinking it's much harder to be able to change these variables down the line?
    Alexander
  • 5.  RE: IAP to CAP
    Posted Jul 27, 2018 07:13 AM
    @wifialexander wrote:
    @mrtwentytwo wrote:
    Hi
    Which model of AP?
    1. Power on the AP
    5. saveenv
    6. boot ap
    Hope this helps
    Alexander
    If you do the convert from the GUI, it does the same, setting the printenv AFAIK. Look at this previous post from 2014:
    http://community.arubanetworks.com/t5/Controller-less-WLANs/IAP-to-rap-apboot-conversion/ta-p/176836
    It should work also on IAP and not only UAP.
  • 6.  RE: IAP to CAP
    Posted Jul 27, 2018 07:16 AM
    @mrtwentytwo
    Oh I did not know that! Thats actually realy useful to know - thank you!
  • 7.  RE: IAP to CAP
    Posted Jul 27, 2018 08:08 PM
    Thanks for the reply, that was helpfule
  • 8.  RE: IAP to CAP
    MVP EXPERT
    Posted Jul 27, 2018 05:46 AM
    Is there a reason you want to complete this before creating a cluster? When the IAP's have created a cluster you can convert them at once either that or you do them one by one.
  • 9.  RE: IAP to CAP
    Posted Jul 27, 2018 05:55 AM
    From the way I read the post,  I think they want an easier way of provisioning them without creating the cluster, (though in my opinion its pretty easy to do).
    Alexander
  • 10.  RE: IAP to CAP
    Posted Jul 27, 2018 08:09 PM
    Just want to know if there is a faster way to do it.
