What is the difference between enabling IP Mobility under Advanced Services which issues the “router mobile” command, compared to enabling Mobile IP within a Virtual AP profile which issues:
wlan virtual-ap "Virtual AP name"
mobile-ip
In our environment we do not need layer 3 roaming, and all AP’s that support a building all terminate to the same controller. We currently do NOT have Mobile IP enabled but we DO have Mobile IP and VLAN Mobility enabled. I don’t think we want either one of these enabled, and am wondering if having these enabled might be a bad idea. Currently if I am at site A and I shut down my laptop and go to site B 10 miles away who has a Virtual AP profile that specifies a different VLAN, I will actually still have the IP from site A even though we do not have Mobile IP enabled, and this is a feature we do not require.
Thanks for your advice!
