If I provision multiple APs with different APgroups but same VAPs will it affect the roaming?
  • 1.  If I provision multiple APs with different APgroups but same VAPs will it affect the roaming?
    Posted May 26, 2015 09:59 PM
    I have building with multiple floors I provsioned Each floor with APgroup but same VAPs for all will it affect the roamin?
  • 2.  RE: If I provision multiple APs with different APgroups but same VAPs will it affect the roaming?
    Posted May 26, 2015 10:00 PM
    As long as the AP groups aren't pointed to different controllers, then no.
  • 3.  RE: If I provision multiple APs with different APgroups but same VAPs will it affect the roaming?
    Posted May 26, 2015 10:01 PM
    You should be fine with roaming.
