Inter User Traffic Per SSID?
  • 1.  Inter User Traffic Per SSID?
    Posted May 23, 2016 11:53 PM
    Can you deny inter user traffic per SSID or Network? I only see you can do this globally under stateful firewall settings.
  • 2.  RE: Inter User Traffic Per SSID?
  • 3.  RE: Inter User Traffic Per SSID?
    Posted May 24, 2016 12:12 AM
    Awesome wasn't aware that was there as well, can this be done at a role level as well?
  • 4.  RE: Inter User Traffic Per SSID?
    Posted Nov 05, 2018 09:25 AM
    Hi Joseph,
    I have a current deployment using 7220 and CAPs running AOS8.3 with no PEF license - this is a hospitality install. The guest SSIDs are all configured in bridge mode. The partner enabled Deny Inter User Traffic under the Virtual AP but he was able to connect two devices to the same SSID on the same AP and ping each other. Do you think this is a bug or is as designed?
  • 5.  RE: Inter User Traffic Per SSID?
    Posted Nov 05, 2018 09:38 AM
    In bridge mode, the firewall is on the access point and the user table is not distributed.  I would open a TAC case to see if the combination of bridge mode and no PEF license is supported for this use case.
  • 6.  RE: Inter User Traffic Per SSID?
    Posted Apr 15, 2019 09:41 AM
    Hi! Any news about this case? I think I have similar problem...
    What ArubaOS version did you use?
