Contributor I
Iphone and IPAD intermitently disconnects with wireless
Hi all friend and expert !
I have some confused issues:
I used IAP 325 and controller 7205
All of my devices are running well, except iphone/ipad/IOS (apple devices), I met some following phenomena:
After connected, it already got IP from DHCP server, but it disconnected and then reconnected.
All of my laptop window, android still run well
Please give me some ideas to troubleshooting this issue
Thank you so much
Lee nguen
Re: Iphone and IPAD intermitently disconnects with wireless
What version of IOS are these devices running?
Contributor I
Dear Conlin
My version is 10.3.3 (iPhone), when i access to Aruba WLAN, it alway connected => Disconnect=> Connecting
I can confirm my phone working well at home, and ruckus. If you want me share my configuration, please tell me.
Thank you so much
LEe
What kind of encryption do you have on that WLAN?
Please make sure you don't have 802.11r, k or v enabled on that SSID.
UPDATE 6/2018 -  The updated RF and Roaming Optimization Validated Reference Design Guide (VRD) has been published and has updated recommendations about enabling 802.11v, k and r in user networks.  The VRD can be found here: http://community.arubanetworks.com/t5/Validated-Reference-Design/RF-and-Roaming-Optimization-for-Aruba-802-11ac-Networks/ta-p/432994
Contributor I
Dear Colin,
For encryption im using:
Mix mode : WPA-AES,WPA-TKIP,WPA2-AWS
For authentication im using:802.1X via Cisco ACS (EAP)
Already disable : 802.11r,k and v
Thank you so much
Lee
You should not be using WPA-AES or WPA-TKIP.  WPA-AES is insecure and WPA-TKIP is also insecure, but forces the client association rate to be 54 megs or less.  In addition, some clients have problems with a mixed-encryption SSID.  You should standardize on WPA2-AES which provides the best speed and security.  To find out what clients could be using WPA-AES or WPA-TKIP, you should use the command:
show dot1x supplicant-info list-all
 That will tell you how many of your clients are using WPA-AES or WPA-TKIP that you need to reconfigure to match WPA2-AES.
Contributor I
Dear Colin,
Thank for your advices
I was change authentication/ encryption = wap2/aes, but iphone/ipad , OSX cannot acess smoothly, it connected and disconnect.
Idont know why, my iphone working fine with ruckus and wifi at home but very difficult acess to aruba system.
Thank you so much Colin
Contributor I
Dear Colin, and all
My topology
Master
Local
master and local different geography.
I have just deloyed in a new building, all the users here will be connected in controller local.
According to my understandings, user connecting into WLAN will be authenticated on Local controller.
But when I check log access on Radius sever (ACS), it is always authenticated by controller master.
I didn’t find any user authenticated on Local at all. However, I still see user list of new buildings connecting into WLAN on local controller.
Please give me some advices
Thank you so much
Lee
Contributor I
I think that is one of rootcause, with apply devides im facing
Thank you
