Iphone captive portal issue
  • 1.  Iphone captive portal issue
    Posted Jul 18, 2017 04:53 AM
    Hi All, we are having issues saying " too many redirects"  with regards to captive portal with Apple devices only. Did try bypass apple  Captive portal Assistant on L3 authentication but no luck".
    No issues with Andriod devices for sure.
    Any suggestions
  • 2.  RE: Iphone captive portal issue
    Posted Jul 25, 2017 03:27 AM
    Hi Bhanu,
    1. Are you using external CP or CP from the controller ?
    2.  if you enable "Use HTTP for authentication" in the captive portal profile as a test, does that helps by any chance.
  • 3.  RE: Iphone captive portal issue
    Posted Oct 29, 2017 02:24 AM
    Sorry for late response . it was isolated issue with Safari browser as everything worked fine using Chrome.
