RobertBW,
You can:
1. Consider a subnet that would be fully routable in your network
2. Create a pool of addresses on the controller for VIA that matches addresses on this subnet, and replace the pool for clients that you are using with it.
3. Create a route in your network for that subnet that points to the controller's management ip address
4. Remove any source-nat statements in the Via user role.
