Issue with connection that uses JAVA 6 only
  • 1.  Issue with connection that uses JAVA 6 only
    Posted May 09, 2016 01:32 PM
    We have a client that requires JAVA 6, it cannot use anything newer than that. If you try to client to it it says no connection in a dialog box from JAVA but the network icon in the sys tray of Windows never loses connection. We tried using it via an ethernet cable and it works fine. I have checked the datapath on the controller to see if it was getting blocked. It is not getting blocked. Any ideas would be helpful? Thank you.
  • 2.  RE: Issue with connection that uses JAVA 6 only
    Posted May 09, 2016 02:55 PM
    We need more details.  What is the client trying to connect to?
  • 3.  RE: Issue with connection that uses JAVA 6 only
    Posted May 10, 2016 12:42 PM
    The client goes to a web page that list all the services/servers that are installed for the Ascom system. The user selects the icon that connects using a JAVA based RDP to a server. This is where the user sees a box saying that they are not connected.The user waits a bout 2 to 3 minutes then it shows the main screen of the server but they click on a device name, it pops the box up again about the connection lost. But it works perfectly fine when hard wired.
