Issues Connectng to Open Guest SSID
  • 1.  Issues Connectng to Open Guest SSID
    Posted Jun 14, 2017 04:51 PM
    We have guest wifi setup throughout our campus enviorment,  occasionaly i get notified that guests cannot connect to the wifi, the only fix that i've found so far is to reboot the access point.  We are running 6.5.1.1, 7905 controller and 325 AP.  I have attached a screenshot of our vap profile for this ssid. If you have anymore questions or reccomendations please let me know. Thanks!
  • 2.  RE: Issues Connectng to Open Guest SSID
    Posted Jun 18, 2017 10:22 AM
    The VAP configuration seems correct.
    There are many potential sources of the problem, you need to give more details. What error message do guests receive? are they using captive portal? do they obtain IP adresses?
  • 3.  RE: Issues Connectng to Open Guest SSID
    Posted Jun 25, 2017 11:43 PM
    Hi Lucas,
    My suggestion will be to move to GA release probably 6.5.1.6 once it is out & then monitor the network.
    Please refer to release notes for higher versions to check for any potential issues on the firmware that you are running.
