Hello guys,
i would know if exist a guide to implement the LAN extension.
i have a controller that have two VLAN:
1) VlAN 1 (MANAGEMENT address).
2) VlAN 20 (for this vlan the controller doesn't have an address)
The controller have two interfaces linked to a switch, fa1/7 (in access on VLAN 20)
and fa1/6 (in accesso on VLAN 1).
I want to propagate by a RAP the VLAN 20, and if i connect to rap's SSID, the controller links me to the switch in Layer 2.
So is like if i am directly connected to my LAN without routing, and i recive an ip by my external dhcp, and the controller works like a L2 switch.
is it possible?
if it is, there is a particular configuration?
Best regards
Andrea
