What are the limitation if i select AP's forwarding mode as Bridge. Will QOS ,Firewall policies (web catagory or IP session based ACL's) work?
I have two different location connected through MPLS. I have 7210 controller placed in both Location and I require that if location 1 controller goes down it should latch to location 2 controller and vice versa.I can see that in tunnel forwarding mode it can be a challlenge hence want AP's to work in bridge forwarding mode. Please suggest if bridge mode will have any limitations!
Will centralized licensing work or i need to add additional licenses on both controller for failure AP;s
thanks in advance.
#7210
