Local Controller Not Functioning and Break Core Switch Operation
  • 1.  Local Controller Not Functioning and Break Core Switch Operation
    Posted Sep 30, 2015 09:14 PM
    Our local controller stop communication with master and now all the AP managed by Master controller. We are facing issue that our core switch is down. After we unplug the local controller cable from core switch, core switch back to normal. Anyone facing this issue before?
  • 2.  RE: Local Controller Not Functioning and Break Core Switch Operation
    Posted Sep 30, 2015 09:15 PM
    How long has this been happening?
    What has been changed on your network?
  • 3.  RE: Local Controller Not Functioning and Break Core Switch Operation
    Posted Sep 30, 2015 09:18 PM
    We facing this issue today and no changes on the network side.
  • 4.  RE: Local Controller Not Functioning and Break Core Switch Operation
    Posted Sep 30, 2015 09:16 PM
    Are you running spanning tree?
    Tim
  • 5.  RE: Local Controller Not Functioning and Break Core Switch Operation
    Posted Sep 30, 2015 09:19 PM
    Hi Capalli,
    U means spanning tree on controller or core switch itself?
  • 6.  RE: Local Controller Not Functioning and Break Core Switch Operation
    Posted Oct 01, 2015 04:33 AM
    You should open a TAC case in parallel.  There are so many things that could have happened; we would only be guessing while your network is down..
