MSR2000 vs. MST200
  • 1.  MSR2000 vs. MST200
    MVP
    Posted Aug 10, 2016 08:44 PM
    Looking for some clarification on the primary differences between the two mesh APs.  What would be the best recommendation for a point-to-point setup where the mesh point would provide uplink to a location without fiber or copper runs.
    Thanks.
  • 2.  RE: MSR2000 vs. MST200
    Posted Aug 10, 2016 09:12 PM
    The MST 200 has a built-in 802.11n antenna and an ethernet port, so it is the most cost-effective way to bridge two networks.  The MSR 2000 offers more antenna options, but if you are just doing a point to point link, the MST 200 is the best way to do it.
  • 3.  RE: MSR2000 vs. MST200
    MVP
    Posted Aug 12, 2016 10:23 AM
    Hi Collin,
    Thank you for the information. So what we would want to do is an MST200 (Mesh Point) to an MST200 (Mesh Portal). And we can uplink a switch from the mesh point to provide remote site coverage. Any idea what the max distance between them is? We have relatively good line of sight. Some trees on either side, but at least 10-15 yards away from AP on either side.
  • 4.  RE: MSR2000 vs. MST200
    Posted Aug 12, 2016 10:48 AM
    Correct, uplink switch on the mesh point is not a problem. Range can be out to 3-4km, but note that the longer the link, the lower the throughput and the APs need to be higher. If you have a distance in mind, we can give you expected throughput and what height they need to be installed.
  • 5.  RE: MSR2000 vs. MST200
    MVP
    Posted Aug 12, 2016 11:02 AM
     Distance appeared to be about 100 yards, height was pretty high, maybe 50ft-60ft?
  • 6.  RE: MSR2000 vs. MST200
    Posted Aug 12, 2016 11:33 AM
    Then you will be totally fine. Throughput should be around 120-140Mbps with HT40, and half that with HT20 (approx).
