Maps For Airwave - USA?
  • 1.  Maps For Airwave - USA?
    Posted Nov 03, 2016 05:47 AM
    Hello there
    We've just deployed several locations in the USA and I would like to add a map to our Airwave for the USA in VisualRF. So far I only have the default map that came with our version which is Europe. The only import options I can find are for Floor Plans, is there a map available for the USA in AMP?
    Many Thanks
    Glynn
  • 2.  RE: Maps For Airwave - USA?
    Posted Nov 03, 2016 08:10 AM
    There are no built-in floorplans.  If you right-click you can use the "set background" option to import a screen capture from your favorite mapping program.
  • 3.  RE: Maps For Airwave - USA?
    Posted Nov 03, 2016 08:46 AM
    Ok great, I knew there had to be something in there.
    Many thanks
    Glynn
