I have a customer who will potentially be deloying a large number of RAP's across a few M3 modules, do you know if there is any restriction on the maximum number of RAP's in a RAP-Whitelist.
The RAP whitelist is stored in the local-userdb. The user-db has a limit of 4000 accounts. I don't know for certain, but I imagine the whitelist (combined with any other local accounts) would max at that number.
Many thanks for the update
Is this limit the same for all code versions?
Matt
Yes.
