Contributor II
Maximum subnet size for WLAN
Hi!
Usually I never deploy bigger subnets than /24 for my wireless clients but I want to ask you guys about the limits if I use drop broadcast and convert broadcast ARP to unicast feature on my VAPs.
With these two features enabled, what's the largest recommended subnet to deploy for wireless only clients?
Thanx,
Re: Maximum subnet size for WLAN
/22 is usually a good size (just over 1000 hosts) and will keep the number of VLANs in your pools down.
Tim Cappalli | Aruba Security
With those safeguards in place, we have seen some of our larger customers use a /20.  Please work with your Aruba SE in case you ever need to grow to that large of a space.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
