Maximum users connected supported 300
I am looking for an access point which supports 300 users minimun. But I need the documentation who supports this feature. I have read a few data sheet. But I cannot find any information regarding this feature.
Re: Maximum users connected supported 300
That hardware does not exist.
Colin Joseph
Aruba Customer Engineering
What if My client wants  4 AP. Which model can support 75 clients so I could handle 300 users sharing the traffic between 4 AP.
225, 325 and 335 APs have more powerful CPUs that can support your number of clients, but you should really scale based on the applications and the number of clients that will be active all of the time...
For example if you are doing an event where everyone is a reporter and actively using their PC, I would only have no more than 30 users/AP. What application(s) would be in use?
Colin Joseph
