Frequent Contributor II
Mesh AP Count
For Controller Capacity , if it supports 1024   campus AP ( Controller 6000  with 1 M3 Module )
RAP is double ( 2048 )
What about Mesh AP ?
Re: Mesh AP Count
2048
If you look on the licensing tab, it will tell you the limits for the platform.
Tim Cappalli | Aruba Security
Re: Mesh AP Count
Thx
is ther command from CLI to check that ?
Re: Mesh AP Count
The CLI will only show you active license limits, not platform.
Re: Mesh AP Count
Thx
what Path from GUI ?
Re: Mesh AP Count
show license limits
Re: Mesh AP Count
i understood from previous post that i will not be able to get it from CLI
so i was asking about PATH from GUI
Super Contributor II
Re: Mesh AP Count
Capture.JPGFrom the GUI, You can see from Configuration --> Controller --> Licenses
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
