Contributor II
Mesh role selection dissapear from Ap Provisioning webUI
This is the most weird problem I ever have with Aruba. After I upgrade to ArubaOS 6.3.1.6 version on a 3600 controller, Mesh role selector from AP provisioning page have dissapear.
I discovered it because i was going to reprovision a mesh portal into a mesh point and I Couldn't from webUI
There is a image from Provisioning page in the attachments
Have i miss something obvious?
Thank you in advance
Re: Mesh role selection dissapear from Ap Provisioning webUI
What browser are you using ?
Thank you
Victor Fabian
Lead Mobility Architect
Contributor II
I have tried with firefox, chrome and IExplorer.
I tried deleting all information from browsers too (historial, cookies...), but didn't work
Thank you
MarcosSemdian,
It is a known issue and should be fixed in ArubaOs 6.3.1.7.
If you need to provision a mesh device, you will probably have to do it on the commandline if you stay on 6.3.1.6;
provision-ap copy-provisioning-params ap-name "Office-135"
provision-ap installation default
provision-ap no external-antenna
provision-ap server-name aruba-master
provision-ap ap-group "default"
provision-ap ap-name "Office-135"
provision-ap no syslocation
provision-ap mesh-role mesh-portal
provision-ap no remote-ap
provision-ap reprovision ap-name "Office-135"
Colin Joseph
Aruba Customer Engineering
Contributor II
Thank you for your answer.
I'll do it from CLI until 6.3.1.7.
Regular Contributor I
thanks for the info, i also was confused why it disappeared.
side annotation  from myself and agreed by aruba.support while i asked them why in "licensing tab" indoor/outdoor mesh disappeared they told it's only optical and mesh still available , and i should use CLI for the moment :
[quote]
With regards to the issue about  missing option  for mesh point/portal provisioning when we tried the flashback up in our controller we were able to see the option to provision as portal or point. In 6.3.1.6 the Indoor mesh entry has been removed from the license tab but still the provision option is available.
[/quote]
i first thought it's perhaps disappeared in arubaOS cause not avail in licenses.. i mean here :
in 6.3.1.5 indoor/outdoor mesh was still there
regards
ben
Ben,
I am not sure there is much to say about it, really.  It is a bug and it is resolved in 6.3.1.7.
Colin Joseph
Well then Support should advice me as customer to upgrade to 6.3.1.7 or to tell about the BUG if it's an official bug , while it's not listed in RN's of 6.3.1.7 unfortunately, that's why i didnt upgrade just ot 6.3.1.7
anyways, im happy to see other people having same issue and so im happy that Airheads people share their experiences amongst others
regards
b/g,
It is in the release notes.  It just does not specify Mesh for some reason.  It is the same issue and the user should upgrade to 6.3.1.7 to fix it:
99961
Symptom: Remote AP settings were missing in the controller WebUI under the Configuration->Wireless- >AP Installation > Provision page. The remote AP license check is removed to fix this issue.
Scenario: This issue was observed in controllers running ArubaOS 6.3.1.6.
Platform: All platforms.
Reported Version: ArubaOS 6.3.1.6
Colin Joseph
yes, saw that, was the only "provision" search term i found. well anyways, it's clearified , i was already confused why mesh has gone, and CLI as workaround is ok .
point.
