I am setting up my configuration to mimic your example in the VRD and noticed a couple of things:
1) The AP’s are on VLAN 92 but there is no DHCP config on the controller nor is there DHCP-Relay configured on the Core switch. How are the AP’s going to receive addresses (I assume you aren’t recommending static)?
2) VLAN 92 for the AP’s also has jumbo packet enabled at the Core Switch but doesn’t continue that setting at the Access Level Switch.
Any feedback is appreciated!
-Travis
