Mobility Controller 7220 Memory usage is too high
Hi all,
I've set up 2 MCs 7220 in a cluster, clients are about more than 2500.
Memory usage of these MCs is always high
Today when I wrote a configuration, at that time the free memory was 45MB, and the authentication module was restarted. All clients are disassociated.
Did anyone have the same problem?
Re: Mobility Controller 7220 Memory usage is too high
probably best to open a TAC case to see what's going on. they can deep dive into the issues and see what potentially is the issue
#AirheadsMobile
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
